Author Topic: Any plumbers on here?  (Read 5233 times)
Offline hobbiniho
Re: Any plumbers on here?
« Reply #20 on: 17 February 2013, 18:10 »
you say its a new build but it must be a bit of age considering the amount of green on those pipes  :lipsrsealed:
Offline dom
  • Back in a Mk4
« Reply #21 on: 17 February 2013, 18:11 »
Right, back to my tap :grin:
Just took the pipe off the bottom of the valve and opened the tap on it, not water other than a tiny dribble. In the morning I'll switch the water off and remove the valve completely, turn the water back on and see what happens.
Offline dom
  • Back in a Mk4
« Reply #22 on: 17 February 2013, 18:11 »
House was completed at the end of august last year.
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #23 on: 17 February 2013, 18:19 »
Okay,i would unscrew the little screw that holds the black tap in place.Take the black tap head off and underneath should be a square shaped head.Get an adjustable spanner and slowly try to turn the square shaped nut.
Offline dixie180
« Reply #24 on: 17 February 2013, 18:22 »
Green on the pipes will be from condensation where cold pipes meet warm air.Not uncommon on cold mains water pipes.
« Last Edit: 17 February 2013, 18:30 by dixie180 »
Offline dom
  • Back in a Mk4
« Reply #25 on: 17 February 2013, 18:43 »
I'll give it a go in a bit :afro:
Offline hobbiniho
« Reply #26 on: 17 February 2013, 18:43 »
yeh its just a bit strange seeing copper pipes with soldered joints in a new house, seems rather outdated to me thought most people used plastic nowadays
Offline dixie180
« Reply #27 on: 17 February 2013, 18:46 »
The older plumbers still like to use solder fittings but don't always wipe the flux off after soldering.Hence the green on the copper pipes.
Offline dom
  • Back in a Mk4
« Reply #28 on: 17 February 2013, 20:15 »
Turned the square nut 360 degrees and still nothing, do I need to turn it more?
Offline dixie180
« Reply #29 on: 17 February 2013, 20:20 »
It should only turn a quarter of a turn.Sounds as if that may be the problem as there are very small stops that make it nion impossible to turn that nut 360 degrees.
