Author Topic: Oil in spark plug chamber  (Read 3829 times)
Offline dom
  • Back in a Mk4
« on: 17 February 2013, 12:29 »
Just want someone to confirm this for me, found oil in my spark plug chambers and on coil packs earlier:
I'm assuming it's the valve gasket that is perished? If so I'll get a new gasket and rocker cover gasket tomorrow from ECP.
Has anyone used loctite gasket sealant before? I'm assuming that I'll need to use some with the new gasket?
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173106_langId_-1_categoryId_255217
Offline vwgolfnut
Re: Oil in spark plug chamber
« Reply #1 on: 17 February 2013, 13:54 »
Yep id say gasket although might be worthwhile checking the rocker bolts are all tighted down just in case of any loose bolts.
I always like to use sealant on any gaskets i replace just to make sure it seals first time!
Offline dom
  • Back in a Mk4
« Reply #2 on: 17 February 2013, 14:21 »
On closer inspection the gasket is visibly damaged (you can just about make it out at 7 o'clock in the picture I posed above).
Will the gasket sealant I posted above be ok to use with the replacement gaskets?
Offline beppe2672
« Reply #3 on: 17 February 2013, 15:18 »
I'd use hylomar mate!
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline brett
« Reply #4 on: 17 February 2013, 20:44 »
pretty sure it was loctite sealant i used when i done the rocker cover gasket on the old mk3 ,never had a problem with it
« Reply #5 on: 17 February 2013, 21:31 »
I would not use sealant, clean the faces and then use a new gasket plus torque bolts to spec.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 18 February 2013, 09:09 »
I didn't use any sealant either
Offline dom
  • Back in a Mk4
« Reply #7 on: 18 February 2013, 09:15 »
Good stuff, any tips Wazzzer? Going to pick the gaskets up soon
Offline dan2252
« Reply #8 on: 18 February 2013, 13:26 »
Yeah don't use sealant Dom could dry and then drop inside the engine then blocking up the pick up pipe
MK4 golf 1.8 turbo agu :)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 18 February 2013, 14:58 »
It's really easy mate, the gaskets locate on the head, just don't tighten the bolts down too much
