Author Topic: Oil leak on my auq head any help welcome :-)  (Read 2060 times)
Offline baxxy
« on: 17 February 2013, 01:32 »
Ok i have an oil trickle down the side of my head it come out of the bottom of these valve shown in the picture below i have changed my rocker cover gasket (used genuine one) but still leaks oil when i have been out in it Red is the valve and blue is where im seeing the oil
« Last Edit: 17 February 2013, 02:11 by baxxy »
Offline Chris#101
Re: Oil leak on my auq head any help welcome :-)
« Reply #1 on: 18 February 2013, 18:10 »
 :grin: what are the chances.....
I have also got a horrendous leak coming from my AUQ180 head which is getting worse and worse, it's running from the area you've highlighted and working its way down the bell housing and  on to my driveway.
What does the valve do?
Seeing as your heads off, have/can you take the valve off via those 3 torque screws and see what affair is sealing it? O-ring, gasket etc
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Chris#101
« Reply #2 on: 18 February 2013, 18:43 »
If anyone has access to a parts diagram for an AUQ180 Head, can you please stick up what that electric valve/sensor is for? and what it actually does within the head?
Offline baxxy
« Reply #3 on: 18 February 2013, 19:36 »
I've been to main dealer for a recall on my coil packs and they said its Sumat to do with them cam that sencer the gasket is only £8 to fix the leak but looks like a big job as them 3 screws holds part of the cam down :-(
Offline Chris#101
« Reply #4 on: 18 February 2013, 20:33 »
Glad you've said that  :shocked: was gonna rip it out tomorrow and see what it was  :grin:
I've got to pick up some bits from the dealers tomorrow anyway  so will enquire and try and get some parts pictures and info and report back :smiley:
Offline baxxy
« Reply #5 on: 18 February 2013, 20:36 »
That's the gasket where it says 8.37 there's an half moon bit aswel
Offline Chris#101
« Reply #6 on: 18 February 2013, 21:43 »
Hmmmm I might whip my rocker cover off tomorrow and see what that valve is doing with the cam :smiley:
How much was the rocker cover gasket?
Offline baxxy
« Reply #7 on: 18 February 2013, 21:44 »
23 quid from Tps mate
Offline Chris#101
« Reply #8 on: 18 February 2013, 21:51 »
Is tps just for trade or can anyone go in and buy parts?
Offline baxxy
« Reply #9 on: 18 February 2013, 22:22 »
I'm not trade mate I just walked in  :smiley:
