Author Topic: mk2 coilovers  (Read 2117 times)
Offline danmusic24
mk2 coilovers
« on: 16 February 2013, 18:35 »
would mk2 coilovers fit mk3 16v?
Offline tweed
Re: mk2 coilovers
« Reply #1 on: 16 February 2013, 19:21 »
they do with mk3 mounts
Offline boneybradley
  • Back in a Mk3...
Re: mk2 coilovers
« Reply #2 on: 16 February 2013, 21:20 »
even without mk3 mounts they will fit (most of the low mk2's now use the vr6 spec mounts)
Offline danmusic24
Re: mk2 coilovers
« Reply #3 on: 18 February 2013, 16:43 »
horrible squeaking noise from rear mounts after fitting coilovers??????
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: mk2 coilovers
« Reply #4 on: 18 February 2013, 16:45 »
Are they new top mounts?
A bit of grease up there will eliminate it.
Offline Metallix
Re: mk2 coilovers
« Reply #5 on: 18 February 2013, 16:46 »
Rear mounts upside down?  I have seen this and it is easily done.
Offline danmusic24
Re: mk2 coilovers
« Reply #6 on: 18 February 2013, 16:52 »
new febi mounts front and rear,will check to make so i fitted mounts correct way as the back still feels likes its swaying a bit and squeaking...could do with a pic of correct way fitting rear mounts onto coilovers if anyone has one?
Offline tweed
Re: mk2 coilovers
« Reply #7 on: 18 February 2013, 17:16 »
Rear end is swaying and squeaking?
I bet the coilovers are used?
Sounds like its leaked its fluid. I hope I'm wrong though and they are new
Gavv8
Re: mk2 coilovers
« Reply #8 on: 18 February 2013, 17:19 »
They do sometimes squeak if they are not tightened down enough.
Offline danmusic24
Re: mk2 coilovers
« Reply #9 on: 18 February 2013, 17:29 »
do you use the long spacer washer from old shocks when fitting coilovers?
yes they are second hand but newish if you know what i mean,no fluild leaks..
