Author Topic: MAF over reading - Log included  (Read 573 times)
Offline Scott D
« on: 16 February 2013, 16:04 »
I installed a Liquid Gauge recently that was showing higher than expected MAF & BHP figures. Have all the usual stage II supporting mods and it is on a standard 180 map.
No fault codes at all, idles perfectly and seems to pull well.
2nd Gear WOT run
   Group A:   '002
      Engine Speed   Engine Load   Injection   Intake Air Mass
   TIME         Timing
Marker   STAMP    /min    %    ms    g/s
   838.05   3160   39.1    3.74           21.61
   838.35   3200   38.3    3.74         21.97
   838.65   3240   39.8    4.08           23.5
   838.95   3240   39.8    4.08           25.08
   839.25   3280   47.4    5.44           31.75
   839.56   3360   49.6    5.1           32.47
   839.86   3480   65.4    7.48           47.53
   840.16   3600   103.8    14.62   83.22
   840.46   3880   148.1    14.28   109.11
   840.76   4160   148.9 14.62           123.33
   841.07   4480   151.9    14.96   130.33
   841.37   4720   152.6 14.96           135.03
   841.68   5040   148.9    14.96   143.86
   841.97   5320   148.9    15.3           151.94
   842.27   5600   147.4    16.32   157.17
   842.58   5800   150.4    18.36   169.97
   842.88   6080   157.1    19.38   179.03
   843.19   6280   148.1    19.04   179.31
   843.49   6520   142.9    18.36   173.19
   843.79   6560   137.6    9.86           178.44
Does anything look odd or may suggest that the MAF could be over reading?
Any one in NW have a spare working MAF or could lend me one for 10 minutes lol
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
