Author Topic: windscreen passenger side condensation. wit's end. help  (Read 1747 times)
Offline Big Tone
After major condensation problems which I thought I'd solved. The bit*h is back!
I have...
Cleared sunroof drains
Cleared door nipples
Cleared rear nipples
Sealed rear vents
Dried out and drained off boot area and proved drainage
Checked door seals
Checked grommets through bulkhead behind glovebox and bonnet cable
Checked all window seals
Checked scuttle panel
Cleared all drainage gulleys/runs
Carpets chairs headliner boot etc are all bone dry.
Car hasnt moved For Two months at least,  started up twice weekly for half hour though
Anyone any ideas?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline barrym381
Re: windscreen passenger side condensation. wit's end. help
« Reply #1 on: 15 February 2013, 23:31 »
have you done the pollen filter
« Reply #2 on: 15 February 2013, 23:49 »
^^This, got to be worth replacing.
Offline harlemex
« Reply #3 on: 16 February 2013, 16:27 »
it wont stop the condensation though  :whistle:
Offline dom
  • Back in a Mk4
« Reply #4 on: 16 February 2013, 17:38 »
It will if that's the cause of water entering the car.
Offline harlemex
« Reply #5 on: 16 February 2013, 18:02 »
Its not.
jockgti
« Reply #6 on: 16 February 2013, 23:16 »
ive just had really bad condensation in car all caused by a wet pollen filter due to the small plastic cover above having a crack in it
Offline dom
  • Back in a Mk4
« Reply #7 on: 16 February 2013, 23:30 »
Its not.
You know that for a fact?
Damage to the pollen filter surround, allowing water to soak into the car through the pollen filter is pretty common.
Offline harlemex
« Reply #8 on: 17 February 2013, 12:49 »
so how is changing the pollen filter gonna sort that ??
Offline dom
  • Back in a Mk4
« Reply #9 on: 17 February 2013, 14:13 »
Changing the filter alone wont, but if he checks his old one & it is soaked then chances are he's found where the water is entering the car. The problem would be the housing, and once sorted he would need to change the filter anyway.
You're either being stupid or pedantic, I hope that for your sake it's the latter.
