Author Topic: Lower Breather Hose Question  (Read 2991 times)
Offline stfc_gti
« on: 15 February 2013, 12:58 »
Just a quick one, I just want to make sure i got it right before i buy anything. Here is a photo of a split pipe i have
Is this the pipe with the arrow in the diagram
Finaly, can i replace it with this silicone hose which i believe with also replace the t-piece in the diagram
http://www.ebay.co.uk/itm/SKODA-VRS-AUDI-TT-1-8T-20VT-PCV-LOWER-BREATHER-PIPE-AUM-AUQ-APY-AMK-BAM-/160960813013?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item257a0317d5
2002 1.8T GTI AUM, Standard (not for much longer)
Offline stfc_gti
Re: Lower Breather Hose Question
« Reply #1 on: 15 February 2013, 13:01 »
last question. can an idiot with no mechanical experience swap it out?
Offline rockmonkey69
« Reply #2 on: 15 February 2013, 13:36 »
The eBay link is not the part you're looking for, the item in that link is for the upper hose which is highlighted in blue on that diagram. It is an easy job to replace the hose and can be done in a short time with the simplest of tools.
Offline stfc_gti
« Reply #3 on: 15 February 2013, 13:55 »
You sure? The description states it replaces parts 2 and 11 in the diagram in the second picture of the ebay link (only just noticed this) which to me looks like the pipe that i need.
Offline GTi_James
« Reply #4 on: 15 February 2013, 13:59 »
say wha...? fit a catch can! problem solved!  :tongue:
Offline cullygti
« Reply #5 on: 15 February 2013, 14:05 »
the one you put a link to is for the lower one as said this one i have put a link to is for the top one which you have put a picture of on here  :smiley:
http://www.ebay.co.uk/itm/Silicone-Crankcase-Breather-Hose-VW-Golf-1-8T-AUM-AUQ-/150993461267?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2327e96013
edit just noticed what you were actually asking  :embarrassed: and the one you have linked to should be fine  :grin:
« Last Edit: 15 February 2013, 14:08 by cullygti »
Offline stfc_gti
« Reply #6 on: 15 February 2013, 14:07 »
rather just get the pipe replaced at the moment, cars going soon so want to keep costs down if possible.
if someone could point me in the direction of a like for like replacement that would be great.
Thanks
Offline stfc_gti
« Reply #7 on: 15 February 2013, 14:08 »
Ok its not the best picture but if you look towards the bottom of the photo you will see the split pipe.
Offline stfc_gti
« Reply #8 on: 15 February 2013, 14:14 »
Offline cullygti
« Reply #9 on: 15 February 2013, 14:17 »
just noticed as i said above  :grin: the one you linked to is fine mate and a doddle to change  :wink:
