Author Topic: what air box to use with mk2 abf?  (Read 3675 times)
Offline bamfish89
« on: 15 February 2013, 10:31 »
Hey guys just wondering what air box to use on my abf converted mk2 golf?
Or is it best to go for a cone filter? If I use a cone filter will I need to make a joining peice to mount the air flow sensor or is there some out there I can buy?
Offline apie2004
Re: what air box to use with mk2 abf?
« Reply #1 on: 15 February 2013, 10:39 »
I've read that a GTD airbox is the one of choice.
Offline Metallix
« Reply #2 on: 15 February 2013, 10:41 »
ABF doesn't have an air flow sensor.  The sensor downstream of the Mk3 airbox is IAT (intake air temp).
Options:
Golf Mk2 GTD
SEAT (ABF) Ibiza, Cordoba, Toledo
Corrado VR6 (with modification)
Cone filters (will require some boxing/ shielding off to be as resistant to engine bay heat as an airbox)
Offline Metallix
« Reply #3 on: 15 February 2013, 10:49 »
extra info:
The SEAT air box has somewhere to plug the IAT sensor into, & accepts the ABF intact duct no problem.
The Mk2 GTD does not have a location for an IAT sensor,  & accepts the ABF intact duct no problem.
The Corrado air box does not have a location for an IAT sensor,  & requires modification to join with the ABF intact duct.
To fit the IAT in a GTD box, drill/cut a hole that is a tight fit for the IAT sensor, then use some sealant.
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 15 February 2013, 10:50 »
Offline bamfish89
« Reply #5 on: 15 February 2013, 13:28 »
Options:
Golf Mk2 GTD
extra info:
Cheers mate thanks for the info.
Have a look here connor!
http://www.clubgti.com/showthread.php?237321-MK2-ABF-Airbox-Choices
Cheera mark ill av a read.
Offline emery1990
« Reply #6 on: 18 February 2013, 17:19 »
you need a seat ibiza gti top airbox bit, then a bottom seat tolado as the gti one doesnt sit, then just an abf inlet pipe.
Thats what I got, real;ly hard to find, I emailed a seat breaker and he had the top bit then some member had the bottom bit, cost about £50 in all.
Offline weazgti
« Reply #7 on: 02 March 2013, 01:37 »
I pulled one out of a vw caddy cos it was a fiver and it fits.
Well it fits in the gap nicely but the studs on the bottom don't line up which I'm sure can be secured another way. It has iat senser aswell.
Offline bamfish89
« Reply #8 on: 02 March 2013, 15:15 »
oh right what sort of cady was it mate? that sounds intersting.
cheers
Offline weazgti
« Reply #9 on: 02 March 2013, 15:55 »
Errr... P reg, must of been diesel one but not 100 percent sure because it was quite a bare engine.
The ones that looke like polos. 6n?
