Author Topic: PCV system pipework  (Read 1154 times)
Offline tom94
PCV system pipework
« on: 14 February 2013, 15:43 »
Anyone got any ideas on the best pipe work for the pcv system and where i can get it, mines letting out alot of fumes!
Offline N900 MJT
Re: PCV system pipework
« Reply #1 on: 14 February 2013, 21:13 »
You will have a better chance posting in the relevant section, or by using the search button
Offline tom94
« Reply #2 on: 15 February 2013, 19:24 »
Allright then, cheers
Offline hobbiniho
« Reply #3 on: 16 February 2013, 16:11 »
easiest option is to delete it and fit a catch can plenty of guides online but it really is a piece of piss, basically take off all the old pipes and "T" the pipe from the crank breather and rocker cover together this then goes to the catch can and then from the catch can to the tip, then block off the hole in the underside of the manifold and reconnect your brake servo pipe and job done you will need a catch can with 19mm inlet and outlet 1.5m of 19mm pipe and a "T" piece
