Author Topic: Tdi 130 duel mass clutch thurst bearing...  (Read 2398 times)
Offline Mk2_tel
« on: 14 February 2013, 15:38 »
How much should I been looking roughly?
Are there better brands of duel mass then others?
Also how much for a garage to do the work is it a long job?
Offline Luke1981
Re: Tdi 130 duel mass clutch thurst bearing...
« Reply #1 on: 14 February 2013, 16:39 »
I was quoted between £600 and £800 to replace the DMF using a sachs kit. Not a cheap job due to entire gearbox having to come off!
What symptoms have you got to suggest its the DMF that's faulty?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline Mk2_tel
« Reply #2 on: 14 February 2013, 17:02 »
Just gettibg louder and when I put clutch in noise goes.
I thought this could just be bearing however I have just had head gasket done
And the garage told me duel mass is on its way out car has done 161k now
Offline Mk2_tel
« Reply #3 on: 14 February 2013, 17:04 »
I think dark side supply to your door full Sachs set up for 414quid???
