Author Topic: whats happened here?  (Read 4558 times)
Offline JC
  • Back in the North.
Re: whats happened here?
« Reply #10 on: 13 February 2013, 17:55 »
febi bilstein ones, renewed a couple of days ago  :sad:
summat wasnt put back right then  :huh: as screech said that smooth portion of the shock shouldnt poke thru  :shocked:
get a picture of how the spring is underneath if you can
Offline Screech16v
  • MK3 20vt AGU
« Reply #11 on: 13 February 2013, 17:58 »
Right apparently there is a circlip that has failed
http://www.golfgtiforum.co.uk/index.php?topic=231306.msg2129123#msg2129123
Offline aidan2112
« Reply #12 on: 13 February 2013, 17:59 »
I have seen this happen to another forum member before,  goes to the search  :whistle:
Search what lol i didnt know how to describe it?
Offline Bellend
« Reply #13 on: 13 February 2013, 18:10 »
Circlip failed. See post above your last.
Where all my moneys went.
Offline aidan2112
« Reply #14 on: 13 February 2013, 18:17 »
Great chaps cheers
 :smiley:
Offline aidan2112
« Reply #15 on: 13 February 2013, 18:20 »
it says that coilovers dont need the circlip?
Offline Screech16v
  • MK3 20vt AGU
« Reply #16 on: 13 February 2013, 18:24 »
I take it you running coilovers then. You must have missed something on assembly then like a small washer,im not to familiar with coilovers sorry bud. :sad:
Offline aidan2112
« Reply #17 on: 13 February 2013, 18:34 »
where abouts would the washer go, i vaguely remember there being one on the other side lol
Offline tweed
« Reply #18 on: 13 February 2013, 18:36 »
Coil over spring cap and bolt should stop that happening.
By the way you only need to undo the top nut to change mounts. They pull of and push on. Can't go wrong  :lipsrsealed:
Offline Screech16v
  • MK3 20vt AGU
« Reply #19 on: 13 February 2013, 18:44 »
Pull it off bud and get a few pics up if it is not apparent whats wrong.
