Author Topic: servicing 2.0tdi  (Read 8279 times)
Offline monty9120
servicing 2.0tdi
« on: 13 February 2013, 16:53 »
hi there my step dad has just brought a 2.0tdi. it doesnt look like its been serviced in a while.
couple of questions. what mm socket is it for the oil filter housing.
what is the torque setting for the oil filter housing?
whats the torque setting for the sump nut?
does the fuel filter need to be replaced they seem rather expensive if so where is this located.
is the pollen filter easy to get to?
most people say castrol edge 5w30 is the correct oil is this correct?. is there any similar slightly cheaper or not?
Offline Rhyso
Re: servicing 2.0tdi
« Reply #1 on: 13 February 2013, 23:10 »
Cant answer 1 & 2
3 is not very tight; something like 20lbs ft  :undecided:
Yes - its only about £20; its located on the drivers side; its the canister with 4 pipes on the top and some allen key screws
Its a pain as its located behind the glovebox
Dont skimp on oil; get the Quantum stuff from VW. Think its 5w 40 and is cheaper than Castrol anyway
 :smiley:
Offline monty9120
« Reply #2 on: 14 February 2013, 21:29 »
does anyone have the torque settings?
is there a way to tell what fuel filter the car has. i want to order the bits but im away from the car right now
Offline Rhyso
« Reply #3 on: 14 February 2013, 23:33 »
Buy a Haynes  :tongue:
Its a cartridge type filter. Get your bits from VW. That way you know they will be right
Offline monty9120
« Reply #4 on: 18 February 2013, 08:42 »
does anyone know the socket size for the oil filter housing. i live over 100 miles from my mum so kinda need to take the right tools :)
Offline monty9120
« Reply #5 on: 26 February 2013, 19:58 »
just to let anyone know the oil filter socket is 32mm
i serviced my mums car. it all went without a hitch. the fuel filter easily refilled afterwards by turning the ignition on and off a few times
the haynes manual. specifys 5w40 but i put in 5w30 castrol edge
the haynes manual says 4.5 litre with an oil filter change. i managed to fill about 3.8 litres
