Author Topic: engine component identification  (Read 1925 times)
Offline dan_thevdub_man
« on: 13 February 2013, 01:09 »
hi guys, i have recently brought an 8v 2.0 gti. and looking under the bonnet came across something iv not seen before. its a pumo/resevoir looking thing with a pin in it tht is sticking out...i can push it in and then it comes out again slowly. its directly behind the immboliser box thing. any ideas?
Offline Abf83
  • Mk3 16v Alpine White
Re: engine component identification
« Reply #1 on: 13 February 2013, 15:52 »
Get some pics up if you can mate. it will help loads to answering your question.
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 14 February 2013, 12:40 »
That will be your low brake fluid reservoir sensor,there should be a little plastic cap that sits on top to hold the stick down,they often come off,you can upgrade the cap for a polo yellow one as it has the same connector.
« Reply #3 on: 14 February 2013, 22:13 »
ok nice one. does it just mean the brake fluid is low?
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 14 February 2013, 23:13 »
No mate  if your fluid is low it will bring a light on the dash,you can use it as is,or just get a new cap ,up to you fella  :wink:
« Last Edit: 14 February 2013, 23:15 by Screech16v »
« Reply #5 on: 14 February 2013, 23:25 »
ok mate brill. nice one.
