Author Topic: Exhaust shield  (Read 1952 times)
Offline N900 MJT
Exhaust shield
« on: 12 February 2013, 08:47 »
Morning all,
Need some help with my exhaust heat shield, basically the front part of the shield under the gear selector was ruined and was taken out (the car currently isn't on the road) but I can't seem to find a new one anywhere!
Is there something else I should use or is it going to be a trip to the local scrappy?
Offline sharki786
  • GOT BOOST??
Re: Exhaust shield
« Reply #1 on: 12 February 2013, 09:32 »
Try the dealers or tps (dont know the price but wont hurtnto find out) if not loads of people breaking mk3s or try the local scrappy as youv said
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: Exhaust shield
« Reply #2 on: 12 February 2013, 09:45 »
When I removed mine I used exhaust heat wrap which works really well and stops the heat transferring into the car.
Offline tweed
Re: Exhaust shield
« Reply #3 on: 12 February 2013, 10:43 »
Yes it does work but that is a lot more expensive than a heat shield. Also doesn't last nowhere near as long.
Offline Screech16v
  • MK3 20vt AGU
Re: Exhaust shield
« Reply #4 on: 12 February 2013, 11:04 »
Its not that expensive tweedy and ive yet to see it deteriorate overtime ,just an option for him geezer.  :smiley:
« Last Edit: 12 February 2013, 11:16 by Screech16v »
Offline tweed
Re: Exhaust shield
« Reply #5 on: 12 February 2013, 11:10 »
Yeah I know. I go through meters of it in karting. Always changing the length of my exhaust and have to replace it a lot. But if you leave it alone its fine.
I would use the stuff if I had a turbo as its lowers engine bay temps, but just saying in this case I think a heat shield would be abetted option.
Offline N900 MJT
Re: Exhaust shield
« Reply #6 on: 12 February 2013, 12:24 »
Well I can freely get hold of exhaust wrap so that might be a good plan :)
Offline Screech16v
  • MK3 20vt AGU
Re: Exhaust shield
« Reply #7 on: 12 February 2013, 12:26 »
Yeah me too ,you cant beat free!  :smiley:
If you do it whilst exhaust still on the car then ppe is a must! as you will be under there a while.
« Last Edit: 12 February 2013, 12:28 by Screech16v »
Offline N900 MJT
Re: Exhaust shield
« Reply #8 on: 12 February 2013, 12:43 »
Hahaha no I can't :) beer tokens ain't that much these days though :p
I will be taking the down pipe off anyway as need to sort out a couple of other bits!
Thanks for the help
