Author Topic: Sensor Problem?  (Read 1683 times)
Offline RichardBaronGolf
Sensor Problem?
« on: 10 February 2013, 14:58 »
Hi everyone,
I have a slight problem with my Mk3 golf gti 16v. Whenever I turn the car over no matter if its already warmed up the autochoke will come on is this normal? It does eventually drop down to normal idle.
Also I pulled up to my drive today and noticed the idle seems slightly lumpy not badly but it was moving up and down slightly! I have a blow in my exhaust at the moment its at the flange on the downpipe and I am going to have welded this week could this be causing the lumpy idle?
I did try putting it on my mechanics diagnostic machine but it wouldn't pick it up :(
Offline spikenipple
Re: Sensor Problem?
« Reply #1 on: 10 February 2013, 16:49 »
It's probably the idle stabilisation valve (ISV). Hook it out and soak it in petrol overnight, dry it, spray a little bit of WD40 down the holes and stick it back in and see if it's any better.
Re: Sensor Problem?
« Reply #2 on: 10 February 2013, 18:38 »
okay mate will try that asap and report back :)
Offline Screech16v
  • MK3 20vt AGU
Re: Sensor Problem?
« Reply #3 on: 12 February 2013, 23:10 »
Check the wires from the tb that run behind the intake above the exhaust mani as they go crispy and earth out .
