Author Topic: Me7.5 dilemma!  (Read 5407 times)
Offline golfyste
  • Project track car
Re: Me7.5 dilemma!
« Reply #10 on: 10 February 2013, 15:32 »
Arz is already dbw!
Runnin me7.1  :smiley:
So same maf etc I think.
Unless I'm missing something and the arz electric throttle pedal is different  :undecided:
Offline Prawny
  • R-tech power!!!
Re: Me7.5 dilemma!
« Reply #11 on: 12 February 2013, 15:46 »
me7-7.5 is much easier than 3.8-7.5 Chris, he just needs to add the lamda wiring and you're off I believe. Don't even need the full me7.5 loom.
Whilst you're doing the conversion, I'd be half tempted to get the EGT setup and loom from an AMK/BAM car and run full eGT control as well and use a BAM file as a starting point for the map.
ESP can be coded out completely yes to answer your original question :)
Offline golfyste
  • Project track car
Re: Me7.5 dilemma!
« Reply #12 on: 12 February 2013, 17:08 »
Always a massive help prawn'  :smiley:
Would it just be get a wideband lambda with 5 wires and then pin it into a certain place on the Ecu plug?
Also what about the vvt?
Don't reAlly know much about working with Ecus but willing to learn about anything!
Again with  adding the egt sensor, would it just be easier to get a bam loom so I can have all the vvt, wideband and egt control without having to mess?
When you say use a bam file, would I need a bam Ecu or just for the mapper to load a bam map on as the base map?
And good to know about the ESP as I don't really want it anyway haha
Cheers mate
Offline golf-sib
  • Турботазик
Re: Me7.5 dilemma!
« Reply #13 on: 12 February 2013, 20:44 »
Look on some European shops and tuning websites, they sell a ready built loom for your 7.5 upgrade from a 6.8.x or 7.1.
My question is why do you want a 7.5 in there? Most 7.5 people end up tuning the drive by wire to work like a cable throttle, mimicking a cable throttle on the AGU, if your not going to use traction control then that's no different than a 3.8.x unit... only real advantage is VVT if your going to add that in. The stuff you want you can be map out. Can even map out additional Lambda sensor and EGT sensor and so on.
Only thing that the ME7.5 will really give you is VVT and Launch control, but launch control is a bit of a gimmick, as all it does is at a given rpm it will apply a load so you can launch of at full capacity, problem with this is, if the tires are better or worse than the launch control you won't get full potential and again same applies to wet/damp conditions, its not like your car knows what your tires are capable of or what the road conditions are.
Variable valve timing is VVT, it can be fitted to earlier 1.8T engines going by the vag catalogue as I was planning to get a AGU engine and breed it with a TT with a BAM engine, except just use the AGU engine with VVT in the TT with quattro on a 7.5 loom.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline golfyste
  • Project track car
Re: Me7.5 dilemma!
« Reply #14 on: 12 February 2013, 21:00 »
The main reason I'm wanting it is for the wideband lambda and the vvt.
The plan is eventually I will be pushing a k04hybrid or similar power turbo to its limits and I want to do it in as safe a way as possible. I know r-tech also have the tiv+ which I believe is for me7.5 only (may be wrong) but the tuning potential of the me7.5 compared to the me7 seems better and I'm wanting to do everything as well as I can with no cutting corners and even doing the little things if it makes a bit of a difference.
I'm not to bothered about launch control (although the new laugh control r-tech is doing sounds crazy  :laugh:) but the new map switching on the standard Ecu may come in handy for wet track conditions and different drivers (me and my dad)
I will have a look for a ready made loom and may be a nice option depending on price!  :smiley:
Offline golf-sib
  • Турботазик
Re: Me7.5 dilemma!
« Reply #15 on: 12 February 2013, 21:04 »
Do an ebay t3/4 kit jobby and get some rods in if your swapping the head, k04 hybrid seems like alot of money for not much gain, ask nick about what the t304 will do at very little boost  :wink:
Downside of the t304 is so many variations, but it will make the 7.5 upgrade more worthwhile.
1.8T AGU..
R135
  24
Offline golfyste
  • Project track car
Re: Me7.5 dilemma!
« Reply #16 on: 12 February 2013, 21:19 »
The engine is Going to be fully rebuilt probably using agu pistons and h beam rods new bearings and valves etc. using a agu head and manifold with aum cams for the vvt.
Why sort of rpm does the t3/4 spool
As I like the idea of up to 340+ hp and low rpm spool like is possible from the k04 hybrid.
Offline Prawny
  • R-tech power!!!
Re: Me7.5 dilemma!
« Reply #17 on: 13 February 2013, 14:56 »
the main benefit of me7.5 has to be the wideband lamda control!
Launch control is a cool feature, but obviously non essential, but wideband lamda is very worth having.
Also on a fwd car the new map switching options and gear based boost sound fantastic.
Offline rio_gti
Re: Me7.5 dilemma!
« Reply #18 on: 13 February 2013, 17:21 »
so this wideband lamda whats this all about?
(ive been following this as i got the arz and i do like the idea of the RAW map ect but not really wantin to do the loom etc)
Offline golfyste
  • Project track car
Re: Me7.5 dilemma!
« Reply #19 on: 13 February 2013, 17:26 »
I can't give you the exact word by word description but it my precise and give more detail than the narrowband following the air ful mix through the rev range whereas te narrow just tells you if it's running lean.....something like that  :laugh:
But I know mapping with it is safer therefore better.
I'm sure prawn can give you a full description!
