Author Topic: Coil over set up  (Read 955 times)
Offline D Squared
Coil over set up
« on: 09 February 2013, 16:56 »
Hi got a set of jom coilies, which when measured for overall length are about 50mm shorter that the original units in free state, is that normal?
Then how are they are assembled? Presumably I drop the spring adjusters right down, less pressure on spring, which allows me then to tighten up the 1st top nut to tighten right up, as it looks like the top spring platform needs to slide down the shocker stem? And what then do i do with the spring adjusters wind up until height required?
MK3-MK5- Now MK7 GTi
Offline hobbiniho
Re: Coil over set up
« Reply #1 on: 09 February 2013, 17:28 »
yeh wind the cups right down and the top nut can be done up easily then adjust to the height required
Offline D Squared
« Reply #2 on: 09 February 2013, 17:32 »
Ok cheers....is it normal for the overall length of the units to be different?
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 09 February 2013, 18:11 »
totally normal.
you should see the avo set a friend has...the body is half as long as the o.e  :shocked:
Offline D Squared
« Reply #4 on: 09 February 2013, 18:21 »
Oh ok....guess when it really matters is when the weight is on them?
