Author Topic: 3 door rear card speakers  (Read 1039 times)
Offline Live in Hope
« on: 09 February 2013, 16:29 »
3 door rear speakers either side of seat are 6.5" can you fit a 6x9 in behind and any probs in doing so?
Offline navmk4gti
Re: 3 door rear card speakers
« Reply #1 on: 09 February 2013, 18:03 »
I also want to know this. Have been doing some reaserch but to no avail. Im going to jus open it up and have a look myself and see if can make some adapters out of mdf :wink:
Offline SI74
« Reply #2 on: 09 February 2013, 19:51 »
Can't see why not, just cut the metal to your new shape.  Tho have you thought about a good set of speakers up front and amp them?
Offline EsSeX dAn
« Reply #3 on: 09 February 2013, 21:23 »
should be able to. like you said make an adapror ring from mdf. remove the old plastic speaker holder and job should be good
i think i love you.....
« Reply #4 on: 10 February 2013, 22:11 »
Yeah will put a decent set up front but wanted 6x9s in rear to add decent bass as i cant have a sub in boot as all space is needed.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 11 February 2013, 09:22 »
Use some mini subs in the rear doors then
Offline navmk4gti
« Reply #6 on: 11 February 2013, 10:28 »
Will need some good sound proofing to stop the nasty rattles  :grin:
« Reply #7 on: 11 February 2013, 21:35 »
Would prefer full range sound in the back and a small amp to power front and rear speakers, where do most on here hide amps in their mk4's
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 12 February 2013, 10:09 »
You won't need full range as you already have separate tweeters
