Author Topic: What Rad should i use? abf conversion  (Read 1431 times)
Offline bamfish89
« on: 09 February 2013, 12:01 »
hey there im in the middle of converting my mk2 type 19 into an abf. i was going to use the abf rad and fan but that means fabbing up alot of brackets which will take a good while. i was wondering if there is another rad i can use that will just fit and do the job? i have my 1.3 rad and fan but will it be big enuff? or mabye i need a mk2 16v rad? any help would be great thanks guys
Offline Dogbot
Re: What Rad should i use? abf conversion
« Reply #1 on: 09 February 2013, 13:23 »
I'm using my mk2 8v item with the plugs changed on the abf loom, the core is deeper than the mk3 abf and my abf runs cooler in the mk2 than it did in the mk3... All goes on std mounts to hope that helps
Offline bamfish89
« Reply #2 on: 09 February 2013, 13:43 »
sweet cheers mate thats what i was after.
Offline weazgti
« Reply #3 on: 10 February 2013, 01:30 »
I did same just need to trim hoses down a bit
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #4 on: 10 February 2013, 06:28 »
I used a long twin fan one out of a seat Toledo which was my donor car. Went straight in. There's room to accommodate different sizes.
