Author Topic: painfull exhaust noise!  (Read 1518 times)
Offline the.little.fox
« on: 26 July 2005, 14:52 »
Hello,
Right I need some help.........
When travelling at speed my exhaust makes a really annoying noise which sounds exactly like a grinder!
I thoght it was probably rubbing on something, but apparently its something come loose inside?
It's a stainless steel scorpion dtm (if that's of any significance?)
I took it into kwik fit the other day hoping they'd look at it for me, but they wont stick it on the ramp!.... too low apparently? it's not that low!!! pussies.
Please help it's driving me nuts!!
Thank you
the.little.fox x
Offline [han]
  • Graphic Designer for Haribo
Re: painfull exhaust noise!
« Reply #1 on: 26 July 2005, 15:38 »
think my aunties car did that, sounded real scary when driving? think hers was fixed by welding something back together... not sure what tbh, but they did it for nothing at her local garage, aparantly it happened all the time but she's not sure what they did either, and my uncles out so she can't ask him! sorry!
Offline westysgolf
« Reply #2 on: 26 July 2005, 15:52 »
jack it up in the air and gently tap each box to see if it rattles. it is possible the baffles in one of the box's is loose. also check the heat shield is not loose around by the manifold/front pipe area
« Reply #3 on: 26 July 2005, 16:19 »
Ah ha! Ye thats the thing thats come loose.... a baffle! Couldn't remember what it was called.
Right then. How do I go about fixin such a thing? How do I tell which bit?
Thanks guys
the.little.fox x
Offline westysgolf
« Reply #4 on: 26 July 2005, 16:30 »
its not something you can fix, you'll need to change the whole box with the dodgy baffles. bit of an arse but its the only way :smiley:
