Author Topic: wire up boost gauge  (Read 1076 times)
Offline stevends
wire up boost gauge
« on: 08 February 2013, 21:31 »
hello, i fitted a boost gauge and wired it up. noe everything is working ok but went out to have a look at it while its dark and it like being in a sunbed. is there anyway to wire it up to the dimmer in the car ?
MK4 Golf 1.8 20V turbo, piper cross induction kit with heat shield, forge 007P dump valve, coilover and a remap !
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: wire up boost gauge
« Reply #1 on: 08 February 2013, 21:35 »
sure, run the live wire to the grey/blue wire on the dimmer switch instead  :cool:
Offline stevends
« Reply #2 on: 08 February 2013, 21:41 »
happy days thanks mate.
« Last Edit: 08 February 2013, 21:45 by stevends »
Offline Golf_GT_TDI
« Reply #3 on: 08 February 2013, 21:50 »
No probs
Offline davemk4
« Reply #4 on: 08 February 2013, 21:59 »
That a good idea ill do that with mine when do it
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
