Author Topic: Coding...  (Read 2706 times)
Offline M3 SHAM
Re: Coding...
« Reply #10 on: 12 February 2013, 17:27 »
Thanks for everyones responces, so far I have installed the RCD 510 which was very easy, however been given the wrong radio code so unable to see if all is working well  :angry:
VW Daybrook should be supplying code over the next few days so will let you know how i get on.
Offline Keithuk
Re: Coding...
« Reply #11 on: 14 February 2013, 17:20 »
Thats something you should always check on when buying a used VW radio. VW should find the radio code via the serial number on the radio but they may charge you.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline M3 SHAM
Re: Coding...
« Reply #12 on: 20 February 2013, 16:57 »
Just a quick update on this changed the stereo too less than 10 mins and all functions are working well.  So in conclusion no coding required  :smiley:
Offline Jimble
Re: Coding...
« Reply #13 on: 20 February 2013, 17:05 »
Happy dayz!! :afro:
Offline dubber36
Re: Coding...
« Reply #14 on: 20 February 2013, 17:41 »
Told you so  :grin: :wink:
