Author Topic: Rust prevention?  (Read 2260 times)
Offline devilscaff
  • allways up for alaugh
Rust prevention?
« on: 07 February 2013, 21:53 »
Iv got a small rust bump on my door sill and want to sort before it gets any bigger, after sanding and removeing any flakes what's a good product to use to stop the rust comming back before painting?
Offline Thom89
  • Looking for an "Icebreaker"
Re: Rust prevention?
« Reply #1 on: 08 February 2013, 00:05 »
Sanding, wire brushing. or chemically treating the rust is only temporary, so I can't recommend any of them!
Grit blasting, cutting out the rust, and welding in new metal, or panel replacement, are the only surefire ways to successfully eliminate rust.
Your best bet is to grind away the rust, and finish with a thin skim of body filler, followed by etch primer, primer and paint, the more thorough the preparation, the longer it will last
Thom
Offline danny_p
« Reply #2 on: 08 February 2013, 00:14 »
haveing experimented with the chemical rust removers i can say they are CRAP  and massivly overpriced as at the end of the day the part of them that dose the work is just phosphoric acid.
all the VW's have gone bar 1.
Offline devilscaff
« Reply #3 on: 08 February 2013, 06:32 »
Ok then out comes the grinder, as usual small job end up being a project.lol
Offline Mr Blue
« Reply #4 on: 08 February 2013, 18:41 »
Just don't burn a hole with the grinder  :grin:
Offline devilscaff
« Reply #5 on: 08 February 2013, 20:45 »
Bound to just to try and create more work, I don't like things going right, I get bored!!!
Offline sparkplug
« Reply #6 on: 11 February 2013, 12:25 »
i share your level of luck  :embarrassed:
1986 GTI atlas grey
Offline tshirt2k
  • Been there...Done that...
« Reply #7 on: 11 February 2013, 14:18 »
Bilt hambers deox gel is good at removing rust. You have to keep it covered whilst it works to stop it drilling out. After its done it's job, you can treat it with hydrate 80 and paint as normal.
Mk3 ABF 16VT Megasquirt V3
Offline weazgti
« Reply #8 on: 12 February 2013, 08:11 »
I allwaus thought the whole point of chemical treatments was to put in the little pitted bits that the grinder couldn't get.
