Author Topic: Seen this on a mk3 gti review  (Read 2453 times)
Offline Leroy
  • Golf GTI Anniversary 16v
« on: 07 February 2013, 15:12 »
"Corrosion is rare on a Golf, which speaks volumes for Volkswagen's rustproofing methods and the quality of the steel it uses. A GTi with rust should scream "badly repaired accident damage" at you. Steer well clear, as a bent chassis will probably have caused misaligned panels and subsequent corrosion."  :laugh:
Offline boneybradley
  • Back in a Mk3...
Re: Seen this on a mk3 gti review
« Reply #1 on: 07 February 2013, 15:49 »
which buyers guide?
I have one from golf+ I will scan this weekend which seems good (from about 2007?)
Offline murraymint
« Reply #2 on: 07 February 2013, 16:23 »
 :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:  :laugh: :laugh:
josh
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 07 February 2013, 17:16 »
Total balls :grin:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Bellend
« Reply #4 on: 07 February 2013, 17:25 »
To be fair not many cars of the same era aren't even more rusty. Astras don't seem toooo bad tbf but a lot of rusty crap about.
Where all my moneys went.
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #5 on: 07 February 2013, 17:39 »
Apparently, due to economic reason, they switched to a lower grade of steel in mid 90's used in later mk3's, alot of early ones if looked after properly seem to be ok in the usual areas, The plastic arches and trim doesn't help matters, also the jacking points were never strong enough to begin with.
Offline Leroy
« Reply #6 on: 08 February 2013, 08:43 »
I can't remember which buying guide it was BB, i typed in mk3 golf 16v reviews but like Jamo said it was probably talking about the early mk3's. mind you if it was written at the time then how would they know they didn;t rust, they would only have been a few years old.
Offline stow1985
  • 'when im cleaning winders'
« Reply #7 on: 08 February 2013, 22:28 »
well thats nice to know   :grin:
I've removed all plastic arches, sills and door trip from mine, not a spec of rust....well apart from the induced bits  :lipsrsealed:
mines a '95 for the record
Offline Leroy
« Reply #8 on: 08 February 2013, 22:33 »
The plastic trim on mine is the only thing holding it together!!!  :cry:
Offline stow1985
« Reply #9 on: 08 February 2013, 22:52 »
bummer  :undecided:
