Golf mk3
hardmonkeys
abs ecu module off with removing brake lines??
Topic: abs ecu module off with removing brake lines?? (Read 1252 times)
vwwvgolf
Here all the time
06 February 2013, 17:59 »
been reading that people have done it with out removing the lines.
HOWW? seems impossiblee
Screech16v
MK3 20vt AGU
Re: abs ecu module off with removing brake lines??
06 February 2013, 18:18 »
Had mine off a few times,you may need to bend your lines slightly then remove it to the right.
vwwvgolf
Here all the time
06 February 2013, 18:23 »
iive bent them and its droped a bit but i feel like im guna brake the lines if i bend them any more. how much can you bend them? are they stronger than im thinking??
Screech16v
MK3 20vt AGU
06 February 2013, 18:26 »
Yes mate they will take a lot to actually break one just make sure you don't kink them that's all.
vwwvgolf
Here all the time
06 February 2013, 19:03 »
its out! gota open it up now lol
cheers for the help pal!
Screech16v
MK3 20vt AGU
06 February 2013, 19:28 »
No probs mate ,good luck getting the lid off ,I tried it on a spare one and kind of wrecked it a bit
Golf mk3
hardmonkeys
