Author Topic: Mud flaps (front)  (Read 1585 times)
LakerLover
Mud flaps (front)
« on: 06 February 2013, 15:18 »
Any tips on removal? Or is it really that straight forward?? Thanks
Offline Rhyso
Re: Mud flaps (front)
« Reply #1 on: 06 February 2013, 15:25 »
Turns wheels for easy access
Undo screws
Pull back arch liner
Remove flaps
Screw arch liner back in
Job done  :smiley:
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 06 February 2013, 15:27 »
I don't remember any pulling back arch liners on mine.
just undid the 3 screws and removed the clip at the top then put the 3 screws back in once removed.
Mk4 Golf 150PD
LakerLover
« Reply #3 on: 06 February 2013, 15:28 »
Schweet im glad its that straight forward!  thanks!!! Was getting fed up of the scuffing!! :)
Offline Rhyso
« Reply #4 on: 06 February 2013, 15:33 »
Fairly sure mine tucked in under the arch liner  :undecided:
Either way; it a simple job!
LakerLover
« Reply #5 on: 06 February 2013, 16:03 »
I suppose you can do it either way by the look of it, anyway I've done it now and I'm not sure about it :/ at least it won't scuff no more! Thanks dude's :D
Offline Rhyso
« Reply #6 on: 06 February 2013, 16:16 »
I always kept the fronts on but ditched the rears
LakerLover
« Reply #7 on: 06 February 2013, 16:23 »
I've got the white VW rear mud flaps and I like the look of them on still! Just the fronts scrapped! I think I would get rid of them if I had some 18's on it as I'm sitting on 17 inch bbs lmrs at the moment! 18s just fill it in a bit better I think!
Offline damien010685
« Reply #8 on: 06 February 2013, 17:26 »
Rear mud flaps are just a no!
Offline Dizzie
« Reply #9 on: 07 February 2013, 11:48 »
I only fitted the fronts since it's just a case of undoing the existing screws and fitting them. Rears require new holes to screw onto.
I'm fitting my rears as I'm bored of my de-wipered rear screen being covered in mud 10 mins after I wash it all off.
Mk4 Golf 150PD
