Author Topic: AND I THOUGHT SHE WAS BACK TO NORMAL !!!  (Read 2449 times)
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
Re: AND I THOUGHT SHE WAS BACK TO NORMAL !!!
« Reply #10 on: 07 February 2013, 14:14 »
Hi Migz,i recently started a thread on here as i was having the same issues with my 8v.My problem was car cutting out with flashing oil light.This was caused by knackered Crank Sensor,which i had replaced.Then i had additional issue with cutting out whilst idling,this was because i had cleaned the throttle body out but didn't realise that it had to be re-aligned using the VAGCOM.Had this done and all is well and car runs really strong.
Do you know what engine you have ADY,AGG etc.Does it cut out with flashing oil light.
Rob
Offline Migz
« Reply #11 on: 07 February 2013, 15:24 »
AGG engine. It cuts out, completely randomly, although more often as i slow down. But has also done it foot to the floor. I cant remember about the oil light, as when the car dies i turn the key off and straight back on, and obviously the oil light comes on just before the car turns over. So if it was flashing i wouldn't have thought anything of it.
Car is at the garage right now getting a new cambelt, but mentioned the car turning off to them when it went in for a service 2 weeks ago and they were adament it was something to do with the distrbutor. So im getting this part fixed as well while its there. But researching about this problem so i know what else to try.
I've found the 45 page long thread about this problem, so if it still cuts out when i get it back going to clean the throttle body, replace the ecu power supply relay, going to replace the ignition switch(needs replacing anyway as noticed sometimes takes about a second after i turn the key to start turning over)
Can you recommend anything else to try thats cheap? Wanna try the cheap things first.
Offline dixie180
« Reply #12 on: 07 February 2013, 15:28 »
Yeah get a VAGCOM diagnostics run on the engine.There are plenty of guys on here with the right gear and know how,depending on whereabouts you live.There should be someone close to you who would help out for the price of a six pack of beer. :laugh:.Like i said if you get this done first you could save yourself a shed load of money replacing parts that don't need replacing.
Plus if there not VW specialists they won't have much of a clue mate.
Rob
« Last Edit: 07 February 2013, 15:30 by dixie180 »
Offline dixie180
« Reply #13 on: 07 February 2013, 15:32 »
VW specialist garage i meant. :grin:
Rob
Offline Migz
« Reply #14 on: 07 February 2013, 15:43 »
Live in Jersey, Channel Islands. Only one person on here whos from jersey and hes gone traveling i think.
I've got one of those VAG scanners that you can buy for about £20 online, would that do the same thing as VAGCOM? I did scan my car with it just after i got it and no errors, but problem started about a week after i scanned, so probably worth another scan.
If its not the same as VAGCOM then will take it to a garage that a friend works at who have VAGCOM.
Offline dixie180
« Reply #15 on: 07 February 2013, 15:46 »
In a word NOPE.You need it scanned with a proper VAGCOM as the one you have is limited to what it can do.At least with a proper VAGCOM you can delete codes and reset almost everything.Well worth the £260 if you have that sort of spare cash. :sad:
Rob
Offline Migz
« Reply #16 on: 08 February 2013, 10:55 »
Unluckily i don't have that kind of spare cash :(. Not after the £320 i spent yesterday to get a new cambelt and get this cutting out fixed.
So far it seems like its worked, hasn't died on me, but will see over the weekend if it dies or not.
For anyone else with this problem the part they replaced was something like a "Distributor amplifier" no clue what that is, apparently its part of the distributor that wears and can be replaced for cheaper then replacing the whole thing. Will have a look to see what the name on my invoice is later on.
