Author Topic: AND I THOUGHT SHE WAS BACK TO NORMAL !!!  (Read 2448 times)
Offline Itteh
  • Built Not Bought
« on: 05 February 2013, 22:35 »
Stupid a** off a car, ht leads replaced, new spark plugs, rotar and distributor cap, she was fine for a day n drove smooth, day later developed cutting out once again !! so i had it tested for faults and fault code came up for Air Intake, and i bort a maf sensor and changed it, for 2 days it ran ever so smooth with no probz at all. up until yesterday the turning off started again and loss of power, so i pulled the wire off the maf, and it helped a little bit but it has a loss of power. the car is really pi**sing me off, i worry taking it far incase it clonks out on me. HELP PLEASE !!!
Offline tweed
Re: AND I THOUGHT SHE WAS BACK TO NORMAL !!!
« Reply #1 on: 05 February 2013, 22:52 »
Relay 30 or 167. Do both
Offline Itteh
  • Built Not Bought
« Reply #2 on: 05 February 2013, 23:13 »
i dno much bout cars, where are they located ? any where near the fuses ?
Offline tweed
« Reply #3 on: 05 February 2013, 23:23 »
Yep above them. There's 2 or 3 white clips and then it all drops down
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #4 on: 06 February 2013, 18:26 »
Hi itteh,have you cleaned the throttle body at all.If you have you may need to get it re-aligned on VAGCOM.
Rob
Offline Itteh
  • Built Not Bought
« Reply #5 on: 06 February 2013, 18:37 »
Nooooo the TB was fine, wasnt touched at all, intake has a problem, as fault wont delete, even tho maf has been replaced.
Offline dixie180
« Reply #6 on: 06 February 2013, 18:41 »
Okay.So i take it you have checked air filter,air intake pipe from filter to throttle body and breather pipes.My breather pipes were pretty gunged up which can cause cutting out.
Rob
Offline Migz
« Reply #7 on: 07 February 2013, 11:19 »
What do you mean by cutting out? My car currently randomly cuts out while im driving and refuses to start for a few minutes. So just looking to see what it could be that needs fixing.
Offline Len
« Reply #8 on: 07 February 2013, 13:02 »
There are so many threads on this! Why dont you lot do a SEARCH? :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline Migz
« Reply #9 on: 07 February 2013, 14:00 »
I usually search but didn't because im at work and its a lot quicker to quickly post in someone elses thread about the same problem. Sorry buddy.
