Author Topic: Correct drive belt for 16v  (Read 1853 times)
Offline mrsaunders
« on: 05 February 2013, 18:49 »
Does anyone know what pas and alternator belt I need on eurocarparts, they always seem to have a big list to choose from and don't wanna get the wrongs ones  :undecided:
Offline tweed
Re: Correct drive belt for 16v
« Reply #1 on: 05 February 2013, 18:51 »
they will be AC and non AC then different brands.
putting in your reg will surely give the right ones?
Offline mrsaunders
« Reply #2 on: 05 February 2013, 19:07 »
That's what I thought, it's non ac, and there all conitech, I'm guessing all the pas belts are the same anyway?
Offline itavaltalainen
« Reply #3 on: 05 February 2013, 19:26 »
Offline mrsaunders
« Reply #4 on: 05 February 2013, 19:43 »
covered about a week ago ;)
http://www.golfgtiforum.co.uk/index.php?topic=247919.0
The descriptions on eurocarparts aren't really helpful, driving mad  :laugh:
« Reply #5 on: 05 February 2013, 20:30 »
« Last Edit: 05 February 2013, 20:34 by itavaltalainen »
Offline mrsaunders
« Reply #6 on: 05 February 2013, 20:36 »
without a/c you need:
v-belt 11.5/11.9 x 685mm
e.g. http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1997/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt/?202440155&1&7ba6f7562303be16f4ef1ccd5c56015104b996f1&000108
ribbed belt 6pk892 or 6pk895 will also do if you got 70 or 90A alternator
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1997/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt/?202120015&1&8cb521afcf81edde869498300cdd99f4d29a9d81&000108
or 6pk1040 if you got 120A alternator (which usually is on diesels or some high spec with lots of electrical extras)
Thanks for the help but got it all sorted, used the avs site, much more helpful
  :smiley:
« Reply #7 on: 05 February 2013, 21:11 »
well.... tbh i use a finnish site for checking which parts i need....
http://www.motonet.fi/web/guest/varaosat
you can display a list of all spares they sell for a model in text form, listing exactly where used...
a lot easier than the sadly more and more "touch" sh!te oriented other websites where it takes ages to find stuff.
only problem it is in finnish and mine is starting to slip (not that it ever was any good)
