Author Topic: 5x98-5x100 16 teledails  (Read 1351 times)
Offline folgate
« on: 05 February 2013, 16:03 »
Hi guys quick one today mates offered me a set of 16" teledails off an Alfa and they are 5x98 will normal bolts do the job or anyone know where to get wobble bolts from and if they're any good
Offline boneybradley
  • Back in a Mk3...
Re: 5x98-5x100 16 teledails
« Reply #1 on: 05 February 2013, 16:36 »
wobble bolts will be ok for 2mm
You do need to check the centre bore as I'm sure alfa's are small (compared to vw) oh and offset too. Pointless buying if you can't get them to fit
Offline folgate
« Reply #2 on: 05 February 2013, 16:46 »
Googled and says Alfa teledials are 58.1mm and golf is 57.1 which leaves me thinking they'll fit I HOPE. will obviously try before to make sure
  • Back in a Mk3...
« Reply #3 on: 05 February 2013, 16:58 »
if thats the case then you just need to locate some spiggot rings and wobble bolts and away you go (well check the offset as you should aim for between et35-et43)
« Reply #4 on: 05 February 2013, 21:45 »
They can be fitted, have seen them on mk2's and mk3's.
Offline folgate
« Reply #5 on: 07 February 2013, 10:22 »
Cheers guys hopefully have them on soon enough
