Author Topic: G60 arches Bonding help!!!  (Read 3256 times)
Offline spekky
  • MK4's my daily driver
« on: 26 July 2005, 08:34 »
OK people anyone who has seen my car knows how low it is now the plan is to keep it that low but now run Design 90's got myself a set of all 16x6j's and rears are spot on no rubbing!!, but will need a bit of arch cutting on the front not a prob being sorted this weekend But can anyone recommend the best adhesive for Bonding on My G60 arches as there ain't gonna be much arch left and certainly wont be able to fix with Rivets at 10 o'clock to 2 o'clock position!!!! on the arch any answers appreciated...
« Last Edit: 26 July 2005, 08:36 by spekky »
Offline vdubit
  • ICE obsessor and Golf Collector...
Re: G60 arches Bonding help!!!
« Reply #1 on: 26 July 2005, 08:52 »
Wurth bond and seal mate. You'll never get them off once they're on!
Offline spekky
« Reply #2 on: 26 July 2005, 08:56 »
cheers mate will keep me eye out for it!!!
 :grin:
Offline spekky
« Reply #3 on: 26 July 2005, 09:04 »
was having a look on the web do you know a good UK supplier???!?
Offline spekky
« Reply #4 on: 26 July 2005, 10:28 »
a little help here Wurth bond and seal uk stockists???
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 26 July 2005, 10:42 »
i use sikaflex, its good stuff (unlike the "no more nails" i used to stick a bodykit on a rover .. well come on it was a bloody rover, and he was a chav ! )
if you're struggling to find anything just pop down to your local bodyworker and ask if you can buy a couple of tubes of bonding agent off them, they usually have dozens of them lying around.
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 26 July 2005, 10:55 »
I used windscreen seal on mine. make sure you cut up the underside fo the arch so the seal gets in and holds on. mine was haven't come off since I roughed it up before sticking them on.
£5 from a windscreen place.
Mk4 Golf 150PD
Offline Ozz
« Reply #7 on: 26 July 2005, 11:32 »
Tiger seal is what I've always been told to use, plus its got the coolest name  :tongue:
Mk2 Gti 8v
Offline spekky
« Reply #8 on: 26 July 2005, 14:28 »
OK having bout as much luck as a Guff in a hurricane rang round a few body shops asked about and zip
been to U-pol and Wurth website but they want a minimum order all i want is on sodding tube of the stuff Arrrgh
Why is nothing ever simple!! :shocked:
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 26 July 2005, 14:38 »
if you get stumped, and fancy a drive into b'ham on saturday, ill be down the workshop and should be able to help you out.
