Author Topic: Dashboard vibration noise  (Read 1199 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 04 February 2013, 11:21 »
The noise comes from the middle of the dash and it starts in fourth gear.
I bought and garaged my golf before fixing it, without testing it on the road so i don`t know if the vibration noise was always there or after because a few months back, I took out the dash to pass an electric windows wiring loom.
Did I not put it back in right maybe that soft foam for the vents were not on properly surrounded?
Offline sharki786
  • GOT BOOST??
Re: Dashboard vibration noise
« Reply #1 on: 04 February 2013, 11:36 »
Could be the sound deading material that you may have not put right. I would also check all the nuts to see if they are tight
*****MK3 Anniversary*****
*****MK4 GTI T*****
  • Golf MK3 GTD
« Reply #2 on: 04 February 2013, 11:48 »
Yes I tighten the outside nuts but it had no affect.
Just to be certain and have everything ready for when I dismantle can I ask, that sound deafening material if its on right or perished,can I use something else or would a vw dealer have it?
Offline vwwvgolf
« Reply #3 on: 04 February 2013, 20:12 »
unfortunately things are never quite the same once they have been taken apart.
could be as silly as a connector or wire touching on somthing somewhere
