Author Topic: Fitting Bora Sport Clocks into MK4 Golf  (Read 9413 times)
Offline gti gurl
Re: Fitting Bora Sport Clocks into MK4 Golf
« Reply #10 on: 11 September 2015, 23:45 »
Yea the ones in my car at the moment are immo3
Im no cactus expert but i know a prick when i see one !!!
Offline itavaltalainen
« Reply #11 on: 12 September 2015, 00:10 »
Easy fit then.... if you have SKC or can get it read.
Offline gti gurl
« Reply #12 on: 12 September 2015, 00:33 »
do you know how much roughly ill be looking at ?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #13 on: 12 September 2015, 21:36 »
No I only re wrote the SKC from the existing cluster/ECU to the cluster being fitted to the car as per the guide on ukmkivs and ross-tech
I use VAG TACHO for the SKC extraction and mileage correction then VCDS for the SKC swap
Offline gti gurl
« Reply #14 on: 12 September 2015, 22:00 »
Nice one  :wink:  I might just go on a few of the mk4 forums on FB and see if there's anyone local that could do it
« Reply #15 on: 12 September 2015, 22:10 »
Have a look at VCDS user map (on vw/audi forum).
As I said might go and see a mate in Essex.... if I do I can stop over to swap your cluster.
Offline gti gurl
« Reply #16 on: 13 September 2015, 10:32 »
That would be brilliant how much would I be looking at roughly as I need payday to hurry up lol
« Reply #17 on: 13 September 2015, 13:43 »
Read your PM again :D
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #18 on: 13 September 2015, 14:27 »
Vagwerkes are only up the road from you in Romford, they coded in and tweaked (miles to empty, lit needles, welcome message) my full FIS Bora Sport / Anniversary clocks.
£40 and about 30minutes chatting on Rams driveway whilst he did the work.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #19 on: 13 September 2015, 16:08 »
Wow I'm massively undercharging to swap clocks lol
