Author Topic: door seals  (Read 3793 times)
Offline Adam78
door seals
« on: 03 February 2013, 22:02 »
hi, anyone know were i can get a seal for my mk2 golf gti 5dr its the drivers side seal not sure what its called but i runs from the wing up the side of the screen then across the top of the two doors. Thanks.
Offline JC
  • Back in the North.
Re: door seals
« Reply #1 on: 03 February 2013, 22:05 »
Offline Adam78
Re: door seals
« Reply #2 on: 03 February 2013, 22:08 »
no not the gutter the seal that runs under it in the door shuts..
Offline Adam78
Re: door seals
« Reply #4 on: 03 February 2013, 23:48 »
No that's the window seal. i need the seal that runs across the top of the front and rear doors you will see it if you open your door it runs up the side of the window and across the top to the back
Offline Lewy
Re: door seals
« Reply #5 on: 03 February 2013, 23:52 »
Clear as mud.
Take a piccy, or Google one.
Offline search
Re: door seals
« Reply #6 on: 04 February 2013, 00:21 »
arnt the front door and back door seals separate? they just run round the inside of each door?
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Thom89
  • Looking for an "Icebreaker"
Re: door seals
« Reply #7 on: 04 February 2013, 00:39 »
That is a perfect description on the roof gutter moulding! tucks in behind the wing, runs up the side of the windscreen, along the roof, and stops near the tailgate, and both doors close against it....
Looks like its in 2 parts, but is actually 1 part
Are we any warmer!
Thom
Offline X4MGS
  • VAG Parts SNOB!!!
Re: door seals
« Reply #8 on: 04 February 2013, 00:40 »
It's called a "Gutter Rail"  :D
and runs from the back to the front, and down the A Pillar...
Check ebay there are a few knocking about...
For More Info Click To See;
Offline X4MGS
  • VAG Parts SNOB!!!
Re: door seals
« Reply #9 on: 04 February 2013, 02:01 »
