Author Topic: inside map light mk4 2001 query? plus trim qs +exhaust jetex query  (Read 1063 times)
Offline davemk4
few things ive looked but cant fins it someone put up on here other day listing of what the inside map light bulbs were. id go and look but it dark and cold and im warm and cosy inside  :grin:
same for the number plate lights?
the wood trim around the drivers door window switchs like the rubbery part is all worn an marked. is this part of door card only?
and lastley anyone else here had fitting issues with Jetex cat backs? my new 2.75'' build quality is spot on but the fitting is shocking. had to cut some chassis parts off, completely re position the rear hanger. it knocks on both chassis and rear bumper and it only clears 2mm from springs. the box has to be sat twisted for it fit so now my pipes are cock eyed which if im honest ive seen loads of golfs and so many have badly fitted back boxes. i went for jetex to get the quality fit and sound etc. sound is about spot on nice burble at idle and under load sound great but when cruising is silent so spot on. now ill be sorting the problem above as im getting a custom front pipe decay made for me so will get them to sort the entire system. just wondered if anyone else had an issue with them?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline sveed1.8T
My bad, miss read that :undecided:
Offline sveed1.8T
With the door trim, I think what you are referring to is the actual handle/trim. This can be replaced and disconnects from the door. Ditch the wood anyway!! :sick:
Offline sveed1.8T
42mm festoon bulb for centre interior light (thats directly above gear stick) and the light either side it are standard 501 bulbs.. the sunvisor light is 36mm festoon bulb
i think the number plate lights are also 36mm if you want to change those  :wink:
Offline davemk4
Yer not keen on wood everywhere it abit nasty like. Cheers for advice :-)
Offline rio_gti
Offline davemk4
Perfect thank you
Offline davemk4
Any views on the jetex peeps?
