Author Topic: gti 8v moving about at rear over bumps,bit bouncy too????????????????????????  (Read 2824 times)
Offline tweed
Feels like is snaking at the rear in a bend? As if the rear wheels are steering?
If yes to them questions its rear beam mounts
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Knackered rear bushes coupled with crap dampers are my bet.
Stuart1971
Sounds like mine and handling went to pot as you describe as normallys hugs corners at speed. Ended up being a leaking shock on near side. Easy to check for leaks visually. I upgraded to gas shocks after the cheaper replacement ones from GSF gave up the ghost on one side after just 3 months. Worth buyng OEM quality rather than the cheap ones if paying for someone else to fit as the cost is in the fitting with shock prices for non OEM very reasonable IMO.
Offline stiffmysteruk
shocks are weeping mostly on passenger side,and got more bounce than a saggy pair tits, :laugh:no which i,d rather have lol
Offline boneybradley
  • Back in a Mk3...
double check your axle bushes while your there.... if failing these can wear your shocks really fast as it twists the shockers!!
cheers dude will do
Offline mrman17
Had this on mine last year - going round corners, the arse end would skip out when going over bumps. Nearly sh*t myself a few times.
A new pair of dampers (shocks) sorted it.
