Author Topic: Picked up my new MKIV V5 - Seriously Annoyed  (Read 3389 times)
Offline JayHoney
« on: 02 February 2013, 22:24 »
Just got back from picking up the V5 and I have to say, I am SERIOUSLY annoyed. Seller lied through his teeth about the car.
When I arrived, it sounded a little lumpy, something I put down to the V5 engine combined with a stupid exhaust/ "Fair enough" I thought. Seemed to drive ok other than 1st and 2nd gear are difficult to select. They seemed just too far to the left. You can select them but it isn't easy
So, did the deal after knocking a bit off for the before unmentioned gear issue and set off home. By the time I hit the M1, BOTH front bearings were making a serious din.....Obviously the seller packed them with grease  :angry:
Gets worse, the lumpy engine got a LOT worse, almost sounding and feeling like one cylinder wasn't firing properly. Nursed her back and decided to try planting the loud button, only to find her a bit lumpy, not giving as much as it felt like she had to give but the 5th cylinder DID come back online.
Switched on the lights and surprise surprise, the passenger side was out but rather strangely, the left indicator only works when the lights are either off or on sidelights  :huh:
So, I HAVE got back, seriously annoyed but it looks like the Golf has to take over from the MR2 as the main project for a while to get it as good as it should be. Any pointers of things to look at tomorrow would be VERY appreciated.
On the positive, the brakes are good, nicely balanced and stopping as they should, the interior, although dirty, is actually in good nick other than a busted cup holder (stuck out) and the bodywork is straight and tidy other than a slight knock on the rear bumper that has cracked the paint....
So, you'll be seeing a lot of me in here. Time to break out the socket set, multimeter and BIG hammer  :angry:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Picked up my new MKIV V5 - Seriously Annoyed
« Reply #1 on: 02 February 2013, 22:30 »
Get vagcom on it. Get it scanned for any fault codes.
As long as there aren't any ridiculous codes I'd then give it a service, get around underneath the car check all the bushes etc see what is what.
Keep us posted.  :smiley:
Offline JayHoney
« Reply #2 on: 02 February 2013, 22:33 »
VAGCOM? I am assuming that is the diagnostic tool for the VW range?
Anything special needed to run this? Leads etc?
Offline brewey
« Reply #3 on: 02 February 2013, 22:48 »
Type Vagcom into eBay and you can get a basic cable that you can use to simply scan for codes. A free version of vagcom is available off the Rosstech website. The diagnostic port is just under the radio cage and above the ashtray with the plastic cover simply pulling off.
It will at least point you in the right direction.
2000 1.8T ARZ - OEM+
Offline damien010685
« Reply #4 on: 02 February 2013, 22:48 »
Why buy a v5??? Also did you not test it before you bought it?
Offline JayHoney
« Reply #5 on: 02 February 2013, 22:57 »
Did test it prior to parting with the cash and it seemed fine - trouble is I think I have just dealt with Arthur Daley car sales. Do just enough to the hide the problems on a test knowing full well that these issues are present and the fix is purely temporary.....
Bought the V5 as it seemed like a good car - how wrong was I? Read up on several reviews and it seemed to tick all the right boxes for me. Some nice low down torque, reasonable power for a daily hack and a good boot.
So, I need to sit back, work out the issues, use the MR2 as a daily for a while and sort this one out. Nothing can't be fixed, it is just how long it takes and how many hammers it takes in the meantime.
So, I will be picking brains, dealing with these faults one at a time. No doubt it can be a good car, the basics are sound, just need to overhaul the mechanics. Not something I am adverse to, that's for sure, just REALLY annoyed that there is a long list already and I have had it less than 24hrs  :angry:
« Reply #6 on: 02 February 2013, 23:02 »
My bad nothing really wrong with the v5 I thought you was looking to turn it in to a beast haha  .... I'm sure u will get it sorted its sh!te when folk lie about Cars sadly that's the world these days!! As said by others get it scaned mate
Offline Rhyso
« Reply #7 on: 02 February 2013, 23:03 »
Is this a private sale or did you buy from a garage?
If its the latter throw it back at them and tell them to fix the problems
Offline JC
  • Back in the North.
« Reply #8 on: 02 February 2013, 23:08 »
Fcuk that - throw back and get money back - they bodged it once - they will again  :lipsrsealed:
« Reply #9 on: 02 February 2013, 23:26 »
If it was from a dealer and speaking from experience getting money back is almost impossible, I had a 4 week legal fight with the dealer over the Rover, not a chance, even after rejecting it in writing under the sale of goods act.
