Author Topic: ABS problems  (Read 2264 times)
Offline madmanmart
ABS problems
« on: 02 February 2013, 20:22 »
Right my GTI has developed a ABS Fault and its not one that I'm aware of.
The ABS light is on, ive plugged in and it comes up with no response from controller.
I checked all fuses and all are fine, I swapped the ABS relay and that made no difference.
Anyone encounted this problem before?
A new ABS ECU is £780+ Vat  :grin:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline Screech16v
  • MK3 20vt AGU
Re: ABS problems
« Reply #1 on: 03 February 2013, 11:26 »
Check your controller/ecu  is plugged in properly, other than that it will be 780 + vat  :grin: :grin:
Offline madmanmart
Re: ABS problems
« Reply #2 on: 03 February 2013, 16:44 »
Yeh tried that, no luck  :sad:
Offline tshirt2k
  • Been there...Done that...
Re: ABS problems
« Reply #3 on: 03 February 2013, 17:01 »
Did you not say in another thread, that you have a replacement?
Mk3 ABF 16VT Megasquirt V3
Offline madmanmart
Re: ABS problems
« Reply #4 on: 03 February 2013, 17:16 »
Different mk3, this problem is on my 40k 16v
Offline tshirt2k
Re: ABS problems
« Reply #5 on: 03 February 2013, 18:02 »
Make sure you are getting voltage to the right pins on the plug. if thats ok, looks like an ecu fault.
40k or 140k makes no difference. There's still heat and water under the bonnet which will affect the ecu.
Offline madmanmart
Re: ABS problems
« Reply #6 on: 03 February 2013, 21:06 »
Right ok, I will have a look.
If I bought a second hand unit and just plugged it in next to the current unit, it could rule of any power or wiring faults?
Offline tshirt2k
Re: ABS problems
« Reply #7 on: 03 February 2013, 21:12 »
That will work if you had the space. I know the ecu fits in the space but doubt the whole thing with pump will.
The thing is. It very likely that the replacement is faulty too.
Offline madmanmart
Re: ABS problems
« Reply #8 on: 03 February 2013, 21:38 »
Are you the man to speak to about repairing it?  :grin:
Or is the old £780+
Offline tshirt2k
Re: ABS problems
« Reply #9 on: 03 February 2013, 21:47 »
I could be. If its repairable.  :wink:
Do you have a part number? Can get it from vag com.
