Author Topic: radiator fans  (Read 1103 times)
Offline Dalo Harkin
radiator fans
« on: 02 February 2013, 19:36 »
When should they come on?
Mine seem to come on not very often at all, temp still sits at 90 though  :undecided:
Offline itavaltalainen
Re: radiator fans
« Reply #1 on: 02 February 2013, 19:54 »
It's not very warm right now is it...  :rolleyes:
They will only start to kick in around 95 degrees... and that is stage 1... stage 2 comes on around 100...105 i think...
check temp with ac codes or use vag com to read temp from ecu (as instruments will sit on 90 between 80 to 100 or 105).
Offline Dalo Harkin
Re: radiator fans
« Reply #2 on: 02 February 2013, 20:10 »
I know it's not very warm, but me giving it the beans on a few occasions should be enough to get them to on in my opinion
Offline dstv
Re: radiator fans
« Reply #3 on: 02 February 2013, 20:13 »
If I can jump in on this post...mine kicks in for no reason...Ill start her up and after a two/three min drive if I switch the car off, the fan kicks in...temp sits at 90 so there is no problem with over heating.. any ideas?
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Offline Dalo Harkin
Re: radiator fans
« Reply #4 on: 02 February 2013, 20:24 »
 That can be the fan controller under the battery box mate, I know it's not that on mine though as I checked it.
Also check fuse F16  :wink:
Offline Chris#101
Re: radiator fans
« Reply #5 on: 02 February 2013, 20:27 »
If you've got ac they should be running all the time. Just on the low speed, then when the car temp goes over 95 the fast speed should kick in. However the fan modules aren't that good and the fast speed resistor 9/10 will have burnt out and you will only have the low speed
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Re: radiator fans
« Reply #6 on: 02 February 2013, 20:49 »
When you give it the beans there is plenty of (currently fairly cold) air to get that heat away.... think about thermostat... it is not an on/off device but gradually opens more and more the hotter coolant gets...
only way to get them running is alternating your right foot hard between the pedals in thick city traffic this time of year
Offline Dalo Harkin
Re: radiator fans
« Reply #7 on: 02 February 2013, 20:57 »
I have aircon, always off though
I just want to double check it's working more than anything or I'll get the air on rad ripped out and an alloy radiator in
Offline EsSeX dAn
Re: radiator fans
« Reply #8 on: 02 February 2013, 22:15 »
they constantly run with the air con switched on. mine rarely come on, probably heard them on twice and once wAs when a rad pipe burst which fried the head gasket :-/ but no over heating problems with mine though now its fixed! you can test them if your ovey fussed, take the fan switch connector off the rad and bridge between 2 of the pins. i cant remember which one off the top of my head
i think i love you.....
