Author Topic: Power steering belt help??  (Read 1810 times)
Offline vwgolf182
« on: 29 January 2013, 22:29 »
Can anyone send me a link to buy a power steering belt  for an 8v gti agg please I'm desperate an can't find one lol
Any help would be much appreciated cheers
Offline itavaltalainen
Re: Power steering belt help??
« Reply #1 on: 29 January 2013, 22:48 »
aircon or no aircon is the question?
non-ac: 11.5 or 11.9 x 685 e.g. Gates 6380MC
ac: 11.5 or 11.9 x 758 e.g. Gates 6310MC
« Last Edit: 29 January 2013, 22:56 by itavaltalainen »
Offline vwgolf182
« Reply #2 on: 29 January 2013, 23:06 »
No aircon
Offline Abf83
  • Mk3 16v Alpine White
« Reply #3 on: 29 January 2013, 23:46 »
Try eurocar parts they also sponsor the forum you may get discount if you type in a code, not sure what the code is but im sure ppl will point you in the right direction. If not try gsf (german,swedish and french).
Offline Len
« Reply #4 on: 30 January 2013, 08:39 »
If you were close I have one that will suit.
If not ECP as they are only about £8
www.sas.org.uk
www.the-ace.org.uk
Offline vwgolf182
« Reply #5 on: 30 January 2013, 09:24 »
Ahh no worries cheers tho.
Wot other title would they come under cos I've had a look an loads came up wasn't sure which one was for power steering. Right struggling to find right one for some reason lol
« Reply #6 on: 30 January 2013, 09:46 »
v-belt
eurocarparts code: LASTCHANCE30 will get you 30% off ;)
ordered some air filters and oil from there for a steal...
Offline vwgolf182
« Reply #7 on: 30 January 2013, 10:24 »
Ah sound cheers for that ill get it checked out
Offline vwgolf182
« Reply #8 on: 30 January 2013, 12:46 »
I've had a look on ecp an it brings like 5 belts up some v belts an some v ribbed which one of these will it be, is the a number or something I can go by??
« Reply #9 on: 30 January 2013, 14:06 »
you need a v belt. 11.5 or 11.9 mm wide and 685mm long.... v-ribbed belt as it says is ribbed which is for the alternator and water pump.
you need e.g.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_1997/p/car-parts/engine-parts/belts-chains-and-tensioners/car-drive-belt/?202440155&1&7ba6f7562303be16f4ef1ccd5c56015104b996f1&000108
