Author Topic: Temperature gauge very low, car slow to heat up  (Read 1286 times)
Offline madsb
« on: 29 January 2013, 20:25 »
Hi guys.
The (coolant?) temperature gauge on my dashboard is usually always low or "zero". It takes quite long even to reach 70-80 degrees. Also the vents take quite some time to put out hot air... There's enough coolant so what could it be? Dysfunctional thermostat?? Anything else?
Cheers.
Offline spikenipple
Re: Temperature gauge very low, car slow to heat up
« Reply #1 on: 29 January 2013, 20:33 »
The thermostat is probably stuck open, get a new one fitted  :smiley:
Offline DCmk3
« Reply #2 on: 29 January 2013, 20:38 »
Either the thermostat is stuck open, or someone never put one in..  :whistle:
2014 Mk7 GTI - Littco L500
Offline Abf83
  • Mk3 16v Alpine White
« Reply #3 on: 29 January 2013, 20:45 »
Im having the same problem it . It takes ages to get to 70 and pretty sure its the thermostat. The top hose to the rad gets hot but the bottom stays cold . The water pump works coz when i open the cap to the coolant tank and rev the engine the water gets pulled down the tank. Ive also changed the temp switch.
Offline itavaltalainen
« Reply #4 on: 29 January 2013, 21:29 »
Does it get to 90 in slow traffic or standing still? How cold is it where you live?
Should go to 90 after approx 10-15 miles /20-25 km the latest in my experience, and i am talking at -20 in a nordic country ;)
otherwise replace thermostat.
