Author Topic: water system  (Read 1251 times)
Offline theviper
water system
« on: 25 July 2005, 12:07 »
just changed a water pipe on the engine and now only got cold air from the heater so how do i bleed the water system
thank's pete :evil:
Offline Mr Blue
Re: water system
« Reply #1 on: 25 July 2005, 12:12 »
that the metal pipe you mean?
Runn the engine with the expansion cap off till it bubbles maybe?
Offline Organisys
  • Old and Slow...
Re: water system
« Reply #2 on: 25 July 2005, 12:28 »
Slide the heater control in the car to hot.
Run the engine from cold with the coolant header tank cap removed.
massage the coolant hoses as the engine warms up, especially the heater matric send/ return hoses.
dont touch the electrics, mind the radiator fan.
when the coolant starts to bubble and then nearly boil, turn off engine.
wait till engine cools, top up coolant if needed, replace cap
Do you have the inline matrix safety valves? you might want to remove them as they can block up.
Re: water system
« Reply #3 on: 25 July 2005, 13:18 »
Don't have to set the heater to hot on a MK2, thats only for the MK1 :)
I find even after doing the hose squeezy thing, sometimes the airlock only clears after taking it for a good thrash down the motorway.  Also when squeezing the pipes rev the engine to 1.5k-2k this makes the water pump run faster which helps get the air out of them hard to reach placed  :grin:
