Author Topic: Wheel nuts  (Read 1923 times)
Offline Mark b
Wheel nuts
« on: 29 January 2013, 14:53 »
Hi all just got some 17" alloys ill be replacing these with my 15" alloys will I need to change all the wheel nuts ? The fitments are the same 5x100
Standard gti 2.0 115bhp 2000 w reg
Offline Toby
  • Car - less
Re: Wheel nuts
« Reply #1 on: 29 January 2013, 16:31 »
no, not unless you have spacers and are removing the spacers.
Currently down under
Offline Mark b
Re: Wheel nuts
« Reply #2 on: 29 January 2013, 16:56 »
Thanks for the reply . No got no spacers it's literally a straight swop swopping for the ones on my sig pic the ones I just got are 7j wide and 35 offset 17" what ever that means
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Wheel nuts
« Reply #3 on: 29 January 2013, 18:18 »
You only new bolts (longer) if you want to run spacers, unsure on offset check this site out...
http://www.rimsntires.com/specs.jsp
standard offset is 38 iirc so running 35 is fine as its very close
Re: Wheel nuts
« Reply #4 on: 29 January 2013, 21:32 »
You will need different bolts as they are aftermarket wheels.
Offline MereKat
Re: Wheel nuts
« Reply #5 on: 30 January 2013, 00:44 »
You'll probably need tapered bolts for aftermarket wheels. I have a full set with locking bolts that I haven't a use for as I've just put the same wheels as your 'old' ones on my mk3 ......... ;)
The offset difference means the center of the new wheels will sit 3mm further out than the standard ones, and with the extra 1" width will sit closer to the arch :)
