Author Topic: help!! abf running problems  (Read 1892 times)
Offline murraymint
« on: 29 January 2013, 07:41 »
Right driving the car to work this morning and on the way work when the revs are at about 2/2.5k it was running rough and wouldn accelerate so I was dipping the clutch, getting it to 3k and it was fine then stopped at a junction and it cut out and wouldn't start. Pushed it to a car park and got it to start but it's running really rough like it's not firing on all cylinders.  Help?!  Checked under the bonnet and the oil is alright, one of the ht leads has dried on oil onit the bloke that pushed me said I might have flooded it 'coz there's a lot of water on the road but it wasn't running right before I got to the water? Any ideas
Josh
« Last Edit: 29 January 2013, 07:43 by murraymint »
josh
Offline tweed
Re: help!! abf running problems
« Reply #1 on: 29 January 2013, 07:57 »
Coil?
Offline murraymint
« Reply #2 on: 29 January 2013, 08:19 »
Yh did some searching around and other threads that sound the same said coil
josh
Offline Dogbot
« Reply #3 on: 29 January 2013, 20:24 »
Had similar on the mk2 abf...  All the signs pointed to coil/injector.... Turned out to be a cup full of water in the ecu.... Snow had melted and found a way in.... It's 4 screws to check...
Might not be but symptoms sound same as mine
Offline RichardBaronGolf
« Reply #4 on: 30 January 2013, 19:00 »
Hi mate just a quick one might be helpful! My car started to run really rough the other day out of the blue, Check your fuse box its under the steering wheel on the right side, Fuse 15 (Counting from the left to the right) is the engine electronics fuse mine had blown
Worth a check :)
Offline murraymint
« Reply #5 on: 30 January 2013, 19:02 »
Ok will check that out cheers bud
josh
Offline murraymint
« Reply #6 on: 31 January 2013, 18:09 »
So put a new coilpack in, run it up to temp. And it started running rough again. Dad said it might be one of the ht leads braking up. So changed them as it seems to have sorted it. No hesitation when pulling away and pulls nice thru the whole rev range. Gunna change the plugs dizzy cap and rotor arm at the weekend but I think I've cracked it!
josh
Offline spikenipple
« Reply #7 on: 31 January 2013, 18:28 »
Cracking  :smiley:
Fitted that exhaust yet?
Offline murraymint
« Reply #8 on: 31 January 2013, 18:47 »
Not yet. Was planning on welding the new tip on the day it broke down, so it's still in the boot  :laugh:
josh
