Author Topic: stage 2 mods with standard map  (Read 916 times)
Offline Scott D
« on: 28 January 2013, 22:09 »
I have an AUQ which far as I'm aware is running a standard map with all stage 2 hardware - full milltek & sports cat, FMIC, ported manifold, induction, new K03s and all sensors replaced not too long ago.
I've got hold of a liquid gauge that has indicated peaks of
MAF = 174gs
BHP = 222 displayed, 217.5 multiplying MAF by 1.25
Torque = 187 ftlb
Torque seems about right and not far off standard but a 40bhp increase from hardware alone seems a lot without any remapping or is that increase usual?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline topher
  • Administrator
  • fully functioning
Re: stage 2 mods with standard map
« Reply #1 on: 28 January 2013, 22:26 »
the bhp/torque figures on my liquid gauge were always miles off what the dyno said.. but that maf reading is pretty high, higher than i'd expect to see on a standard ecu. Its possibly remapped already or has an over reading maf sensor. What does the liquid's boost gauge show?
Offline Scott D
« Reply #2 on: 28 January 2013, 22:47 »
not checked with liquid but the newsouth gauge its spiking to 13psi then holding 9/10psi only dropping slightly
still on the same standard map as when it left after having the K03s fitted, could well be the MAF over reading.
think a dyno run is defiently needed to be sure
Offline Chris.
« Reply #3 on: 01 February 2013, 11:58 »
ECU should be capping boost as soon as it see's it.....I doubt a exhaust and TIP + FMIC would let the ECU see overboost, but I could be wrong.
Click For Build Thread
