Author Topic: Tandem Fuel Pump  (Read 8445 times)
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Tandem Fuel Pump
« on: 27 January 2013, 10:08 »
Changed my tempreture sensor and thermostat yesterday as one of them was playing up so just done the two but as I had the car running and I was looking around the bay I noticed on the Fuel pump on the side of the engine there was some very faint air bubbles im guessing fuel,the leak wasnt bad but still enough for me to notice it so I intend on getting it sorted.A friend of mine who I gave a call about it reakons there was a VW recall back in 2005 something to do with the bolts so he suggested give VW a ring on Monday but im not really sure if VW would still carry out the fix if there was a recall?Failing that is it just a case of replacing some gaskets or a new fuel pump?Has anyone else came across this problem thanks..
Golf Gti
Offline sveed1.8T
Re: Tandem Fuel Pump
« Reply #1 on: 27 January 2013, 10:28 »
I know you're reluctant to take a pic of your dirty engine bay, but this is a time where a pic will paint a thousand words! :whistle:
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #2 on: 27 January 2013, 10:34 »
There was a some kind of recall but I had no luck with it, they looked my car and up and said no recall listed so I replaced the pump myself back in November, bought a brand new one from darkside and followed this guide...
http://elsaweb.spaghetticoder.org/doc/V.en-GB.K00510081/34692684/3
It was an easy job, no leaks since  :cool:
So depending on where yours is leaking exactly you may just need a new gasket, they are either o-ring type or metal plate type, dep on model year/engine number (always use same version thats fitted to your car)
« Last Edit: 27 January 2013, 10:36 by Golf_GT_TDI »
Offline tdi_blu
« Reply #3 on: 27 January 2013, 10:50 »
I can take a picture ill see if I can actually get one of it leaking.If you was looking at the pump side on where the bolts go in the first part is like a plate thats where its leaking from at the top if you get me lol If not ill try a get a picture posted later...
Golf Gti
Offline Golf_GT_TDI
« Reply #4 on: 27 January 2013, 11:32 »
Found this topic which may help you with the end plate...
http://uk-mkivs.net/forums/p/315312/2108998.aspx#2108998
Offline tdi_blu
« Reply #5 on: 27 January 2013, 16:54 »
Thanks for that mate that is where mine is leaking from ill pop into TPS tomorrow see if I can get the gasket for it.I might have ago myself as it looks easy enough thanks again for that link  :wink:
Golf Gti
Offline Golf_GT_TDI
« Reply #6 on: 27 January 2013, 21:48 »
You can get the o-ring or metal gasket for the cyl head side but the end plate gasket is not available to buy, people have tried but afaik no-one has yet been able to find one. Its meant to be a non serviceable unit and there are no spares bar the main gasket.
You can unbolt the end plate and seal it as that guy has done, thats your best bet.
Offline tdi_blu
« Reply #7 on: 31 January 2013, 10:23 »
Ive just rang TPS and they reakon they do a complete gasket kit now for the pump that includes that seal ill let post up if there right as you never know they may have it wrong..
Golf Gti
Offline Golf_GT_TDI
« Reply #8 on: 31 January 2013, 13:28 »
Thats great news if true, but I don't think its likely, here is a screengrab of the pump and the two types of gasket...
Offline tdi_blu
« Reply #9 on: 31 January 2013, 18:30 »
Yep you was right they only supply the gaskets above  :angry: so im gonna reseal it with some gasket seal well follow that thread you posted thanks again  :wink:
Golf Gti
