Author Topic: rear wiper  (Read 2141 times)
Offline Adam78
rear wiper
« on: 27 January 2013, 10:07 »
i have a problem with my rear wiper cant seam to get it to work properly silly question as i am new to mk2 golfs but what position on the stork operates the rear wiper. i can't get it to work but when i spray the rear jets it works and continues to work and then i can't turn it off untill i switch engine off and restart and then same problem wont operate off the stork any suggestions please
Offline oakgreener
Re: rear wiper
« Reply #1 on: 27 January 2013, 10:17 »
Push the right hand stalk away from you to start intermittent wipe. It'll continue to wipe until you push it away again.
Turning the ignition off also stops the wipe. :smiley:
Welcome to the world of proper motors :smiley: :smiley: :smiley:
Offline Thom89
  • Looking for an "Icebreaker"
Re: rear wiper
« Reply #2 on: 27 January 2013, 11:43 »
As above, though there is a possibility that you have broken wires where the loom passes from the roof, to the tailgate, check that both number plate lamps are working, and the heated rear screen is also working...
Broken wire should be repaired with solder and heat shrink insulation
Thom
Offline JimR
Re: rear wiper
« Reply #3 on: 27 January 2013, 14:05 »
I had this when I bought my first mk2, as said, slight push away starts wipe, slight push away stops wipe, big push away squirts rest window.
Mk2 GTi.
Offline dubber36
Re: rear wiper
« Reply #4 on: 27 January 2013, 18:26 »
I always thought it was a stupid switch design, right back to when I first drove a Mk2 in 1988.
Offline Adam78
Re: rear wiper
« Reply #5 on: 27 January 2013, 18:43 »
Thanks mate worked it out now :smug:
Offline search
Re: rear wiper
« Reply #6 on: 27 January 2013, 19:39 »
delete it.  :wink:
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline antogoof
  • bbm mk2 g60
Re: rear wiper
« Reply #7 on: 27 January 2013, 23:50 »
yeah what do you wanna see whats behind you for! :evil:
mk2 bright blue met bits wanted in north west.
