Author Topic: Induction Kit  (Read 3925 times)
Offline number_six
Induction Kit
« on: 09 October 2003, 18:42 »
Hello Peeps
I'm no modder or really that clued up on engines, but.....
Has anybody fitted an induction kit to their MK4 1.8T GTi?  if so...
What type?
Was it easy to do?
Did it make much of a difference to the performance?
That's quite a few questions there.
Cheers for your responses.
Six
Offline sie18t
Re:Induction Kit
« Reply #1 on: 11 October 2003, 12:22 »
Keep your money !!!!
I put a ITG Performance panel filter in and it went fine for a couple of weeks then the car started cutting out whenever I came to a junction etc.
Took it off, had no probs since
Performance is just the same !
golfvr6
Re:Induction Kit
« Reply #2 on: 11 October 2003, 13:19 »
K&N do a good kit, strange you had problems mate cos i've always put induction kits or panel filters in my cars with no problems.
kniterider
Re:Induction Kit
« Reply #3 on: 11 October 2003, 20:08 »
unless your plumbing the filter into the front air dam/bumper you can expect MAF sensor probs which will cause car to run rough, stalling, excessive fuel use etc, dont know why but check uk mk4s website  for more info, alot of people just run panel filters in there orig airboxes to avoid probs as MAF sensors between ?70-?90 to replace, you can clean but they f$?7 up in the end
golfvr6
Re:Induction Kit
« Reply #4 on: 15 October 2003, 21:51 »
Go for the induction kit, the airflow meter will work fine with it.
kniterider
Re:Induction Kit
« Reply #5 on: 16 October 2003, 17:04 »
your choice! i wouldnt mind trying one on mine but im gonna keep the engine etc all standard, got my mk2 to mess about with
