Author Topic: quick way to do rear top mounts  (Read 1027 times)
Offline dubpirate
« on: 26 January 2013, 16:04 »
my mk3 is slammed just wanting to replace the rubbers got sum febi gear
just wandered can I undo em inside jack the rear and swap em and put it back down
is this a quick way if it is on its arse
cheers dan
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: quick way to do rear top mounts
« Reply #1 on: 26 January 2013, 16:40 »
Yes you can do it that way with coilovers but will need to drop both sides as the same time so you will need to support the rear beam from dropping down to far.
