Author Topic: Door handle seals  (Read 1861 times)
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
Door handle seals
« on: 26 January 2013, 10:53 »
Anyone know if and where you can buy these from as im looking at replacing mine but can only find complete handles on the bay?Thanks Lee
Offline itavaltalainen
Re: Door handle seals
« Reply #1 on: 26 January 2013, 13:48 »
which ones?
i assume 18 (1H0837209) or 19 (1H0837211B)? vw would have them, only ~2£ ea.
Offline Leebob
« Reply #2 on: 26 January 2013, 13:53 »
Yeah there the ones.If I cant find them anywhere else I guess it will have to be the dealers.
Offline col-mk3
« Reply #3 on: 26 January 2013, 14:44 »
i have to pull my handle's loads to open my door what would i need to sort that?
« Reply #4 on: 26 January 2013, 16:16 »
which handle, inside or outside one?
Offline col-mk3
« Reply #5 on: 26 January 2013, 20:39 »
outside
« Reply #6 on: 27 January 2013, 11:01 »
Sorry, I can't remember how the outside one hooked up to the central locking block exactly....
To take the handle out you need to undo the top torx screw on the side of the door (i.e. where the lock catch is).
Then you might already see what's gone wrong. If not it's a job of removing the central locking block, part disassemble and clean.... usually having to pull hard means that some of the mechanics are either frozen or seized up.
Offline Whimsa
« Reply #7 on: 02 February 2013, 03:23 »
I had this issue and found it was the spring from the catch that broke. Basically when you pull the handle the catch should spring up so you can just pull the door.
Offline col-mk3
« Reply #8 on: 02 February 2013, 13:29 »
so did youjust put new spring in? and is there part number?
